Threads: 3
Thanks Received: 1 in 1 posts
Hi, everyone,
I have a strange problem lately, between 70-100 km/h the car/engine shakes wildly unless I press very minimally on the gas pedal.
This also happens when there is a positive slope on the road.
At low speed on the plane the problem is almost non-existent
Feels like the engine is struggling to give 'power' between 70-100 km/h and uphill. Above 100 it more or less disappears.
No engine computer related issues
Does anyone know what the problem might be?
Berlingo diesel 1.6hdi 9HW 2008
Threads: 75
Thanks Given: 223
164
Imbalance in the drive shafts?
Threads: 29
Thanks Received: 38 in 33 posts
Thanks Given: 146
11
Now that I've recovered from the Parkinson's monicker, the fact that the issue you have seems to change at a given speed, and with gentle throttle control does not amplify the problem, I'd say loose engine mounts are a highly likely possible cause. I've had exactly that same symptom from my transit connect a couple of years ago from a sheared engine mount.
Sent from my ANE-LX1 using Tapatalk
Threads: 13
Thanks Received: 32 in 24 posts
Thanks Given: 8
Engine mounts - my 2.0Hdi does it. I have a thread on here about it but it's effectively mount rubber is too soft, it's fine in winter but starts juddering again when the weather warms up.
I've changed all mounts including a PU rear bush, still does it.
Use a lower gear and a few more revs.
2004 Peugeot Escapade 2.0HDI. 115k miles
2004 Volvo V70 2.4 208k miles
2011 Volvo XC90 215k miles
2005 Porsche Cayenne 170k miles
Threads: 67
Thanks Given: 237
50
I like the easy approach first ..... give the fuel a hefty dose of injector cleaner
Give it a week to run through and see if it solves your issue.
Don't laugh you may find it works ..... I used to get a regular " anti-pollution " fault whe driving in town and giving a regular injecotr cleaner dose sorted that for me.
Serieal Berlingo owner
Threads: 3
SOLVED
It was the control arms, after replacing them and the drive shafts - the problem was solved.
Thank you all ?
The following 1 user says Thank You to gonzo2227 for this post:1 user says Thank You to gonzo2227 for this post
• geoff
