Satnav new home
I have at last gotten around to fitting a satnav (or such)  mount in the cubby hole on the dash in front of the driver. I made cardboard attempts before going to plastic but in the end I went to metal.  The unit is held on the mount currently with a cable tie but that can be improved later.
Clearance was a big issue so the lid would close and to an extent that is what took the time........measurements.
Also I wanted the rear camera screen to fit in but there is not enough room for the two. Sad Sad
Make life easier - go automatic. Cool
What's all that on the leading edge of the dash lid?
Sent from my ANE-LX1 using Tapatalk
(18-04-2023, 02:19 PM)jemselectrical Wrote:  What's all that on the leading edge of the dash lid?
I think it is just a camera aberration. Confused
Berlingo digital cluster speedometer upgrade
Last Post: kaktusas
Yesterday 02:48 PM
Cruise control retrofit
14-12-2025 09:37 PM
14-12-2025 01:33 PM
14-12-2025 12:49 PM
14-12-2025 12:00 PM
Anti Pollution fault warning
14-12-2025 11:39 AM
An almost Hydrolock in a DV6B
Last Post: chrisl
14-12-2025 09:36 AM
Last Post: chrisl
14-12-2025 09:27 AM
tyre pressure monitoring system (TPMS)
10-12-2025 07:50 AM
Wishbone Lower Control Arms Questions
09-12-2025 07:19 PM
