[Engine] Berlingo 2.0 HDI engine fault in wet weather
Hello everyone, I’m hoping one of you guys can help me out with an extremely annoying fault on my 06 2.0 HDI multispace. Basically the thing acts up in the rain but drives completely fine when it’s dry. The engine management light comes on and it’ll either not start up once turned off and as soon as it drys out it’ll be fine again or it’ll loose all throttle when driving. I’ve checked the bsi and that’s all dry, I’m thinking it could be a loom problem ? any ideas ?
Threads: 46
Thanks Received: 155 in 125 posts
Thanks Given: 34
21
21-04-2023, 08:29 AM
(This post was last modified: 21-04-2023, 08:31 AM by Multispacer.)
(21-04-2023, 08:01 AM)Beefomatik Wrote: Hello everyone, I’m hoping one of you guys can help me out with an extremely annoying fault on my 06 2.0 HDI Multispace. Basically the thing acts up in the rain but drives completely fine when it’s dry. The engine management light comes on and it’ll either not start up once turned off and as soon as it dries out it’ll be fine again or it’ll loose all throttle when driving. I’ve checked the BSI and that’s all dry, I’m thinking it could be a loom problem ? any ideas ?
From memory [I had an M59 Multispace in the past] The main loom to the BSI runs from the engine bay into the interior through a large rubber bung that is located underneath the rain scuttle. To get access to check in that area you need to remove the wiper blade arms and there are about four torx headed bolts holding the rain scuttle in place. In the area where the loom goes through is also one of the drains that lets water out of that area to below and it does sometimes get clogged with muck and leaves etc, so that might be where your problem is but I wouldn't think so as the fact that the problem goes when the car dries out, to me indicates, it is somewhere more exposed, as if the box section where the loom goes through into the interior was getting flooded, it would probably take a long time to dry out but definitely worth a look to eliminate.
When you say the BSI is dry, have you actually had any [all?] of the plugs out on the BSI? If water is running down the main loom through the bung from outside, then it could be that water is wicking into one of the plugs and shorting out inside a plug. Obviously if you are going to disconnect the plugs to check, make sure you go through the correct BSI shutdown procedure and disconnect the battery.
Threads: 46
Thanks Given: 34
21
I should also add there is another area that has a number of connectors/looms that are also connected to the BSI that is in the engine bay itself. Again from memory, it is either to the right of, or behind where the battery is located there are a number of fuses and connectors in there. I had a number of them out on my M59 as I had an 'Airbag fault' which was actually an open circuit wire, so I was doing wiring checks in there. It only has a plastic cover and I have seen reports of this area getting flooded causing electrical problems on both the Berlingo and other Citroens. Again, it was plugs getting water in causing all sorts of problems.
(21-04-2023, 08:39 AM)Multispacer Wrote: I should also add there is another area that has a number of connectors/looms that are also connected to the BSI that is in the engine bay itself. Again from memory, it is either to the right of, or behind where the battery is located there are a number of fuses and connectors in there. I had a number of them out on my M59 as I had an 'Airbag fault' which was actually an open circuit wire, so I was doing wiring checks in there. It only has a plastic cover and I have seen reports of this area getting flooded causing electrical problems on both the Berlingo and other Citroens. Again, it was plugs getting water in causing all sorts of problems.
Firstly thanks for taking the time to reply to my post ?? So here’s a little list of things I’ve checked/looked at so far:
I’ve unplugged, removed and checked over the BSI and there wasn’t any signs of water ingress
I had the scuttle covers off and checked the drain holes and they were all clear
I took all the visible loom plugs off the engine and contact cleaned them but I’m still getting the fault in wet weather. It seems to happen if I drive through puddles ?
Threads: 11
Thanks Received: 32 in 32 posts
Thanks Given: 3
7
I know the cure. Don't drive through puddles.
Geoff
Threads: 43
Thanks Received: 410 in 367 posts
Thanks Given: 137
31
If the EML comes on there may be a fault code ?. Try to scan to see, it may give a clue .
Is the engine bay fusebox fuses dry and the connections to it, don't know if its reachable by splashing puddle water but if the cover is loose ?
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(21-04-2023, 05:49 PM)brodfather11 Wrote: If the EML comes on there may be a fault code ?. Try to scan to see, it may give a clue .
I did check the fuse box in the engine bay and it’s bone dry, I checked all the earths too and they all seemed fine… it flags up p1351 and p1641 when the EML comes on which is a short in injector power stage I think…
(21-04-2023, 05:40 PM):DGuanock Wrote: I know the cure. Don't drive through puddles.
Geoff
Threads: 43
Thanks Given: 137
31
If your code reader is not lexia it may show false codes. P1351 as far as I can see is for a petrol engine
various "High voltage circuit failure " depending what make of car. Cant seem to find p1351 for Citroen.
The 1 in the code is a make specific code for a Citroen code. ie it means something for a Citroen which will be different for a Ford etc.
P1641 says a primary fuel pump circuit failure. If yours has a electric pump in the tank then possibly the wiring to it or on top of the tank is dodgy.
Threads: 75
Thanks Received: 1,308 in 1,140 posts
Thanks Given: 223
164
22-04-2023, 10:29 AM
(This post was last modified: 22-04-2023, 10:33 AM by Sol.)
P1351 is a glow plug system fault. (Pre-heating relay circuit : Coherence ; Relay supplied and glow plugs not supplied. The information from the preheating control unit indicates that the relay is open even though the ECU commands the closing of the relay for 5 seconds)
P1641 is an injector system fault (Computer : Failure of the initialisation of the injector bank, or harness)
Both together sounds like an engine harness fault or a blown main fuse. Mice perhaps or chafing of the harness is a possibility. Also worth checking all ECU plugs for good connections.
But do not unplug any ECU plugs with the battery connected.
Berlingo undertray
Today 07:37 PM
» Replies: 22
Air filter box removal
Today 06:50 PM
Yesterday 10:10 PM
» Replies: 21
Yesterday 04:25 PM
Yesterday 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
