Threads: 2
Hi all
Marc from Nottingham i have a 2.0 hdi multispace great little car
Would like to change cambelt.
Tbh i cant afford garage prices, cant afford to kill engine so need to change myself
Is there a guide or any info available please? Or anyone near Nottingham thats not going to have my trousers down to replace
Many thanks Marc
Threads: 123
Thanks Given: 250
34
There are plenty of 2.0HDi cambelt videos on You Tube that will give you a feel of what's needed. There are a few variants of the 2.0 engine though so some details may be a little different.
If you take a look at some videos, it'll probably bring some questions to mind that you can get answered here.
Thanks Given: 39
13
Haynes manual worked ok for me.
As mentioned before on other threads there are no issues with fuel injection pump timing as is common rail.
The vehicle with 2.0 hdi I worked / work on is a Dispatch so maybe had luxury of a bit more space. I found the job fairly straightforward, wouldn't want to charge myself an hourly rate though for the time I took though.
What I would say is make a mental note of how tight the old belt is before you slacken it off. Is easy to over tension the new belt
Threads: 25
Thanks Received: 27 in 26 posts
Thanks Given: 16
6
(28-04-2023, 07:41 PM)Kieron G Wrote: Haynes manual worked ok for me.
Can you do the '90 degree twist' trick with these?
My van: 2008 Berlingo 1.6 HDi Enterprise - a bit ratty!
Threads: 123
Thanks Given: 250
34
29-04-2023, 08:23 AM
(This post was last modified: 29-04-2023, 08:24 AM by cancunia.)
The tensioner has a marker to show when it's at the correct tension, so f you are putting a new belt, rollers & tensioner on there should be no problem. Probably a good idea to replace the water pump at this time too if it's not already been done.
Thanks Given: 39
13
You're right of course cancunia, I forgot about the notch in the tensioner, was thinking of the DW8 that I had to go back and slacken as was making a humming noise because was a bit tight.
Yea RC I think the 90 twist on longest stretch works, I just was using too much effort to get that 90 first time I changed on the DW8
