Threads: 69
Thanks Received: 22 in 22 posts
Thanks Given: 7
4
Hi all ,anyone help me please, i know the paint code is on a label on the door frame !! but what actually is the code ? is it the numbers or the letters or both ?? TIA Gwyn
nice to be important,more important to be nice
my ride is a berlingo forte 1.9d 2003 model in pukey blue
Threads: 29
Thanks Received: 38 in 33 posts
Thanks Given: 146
11
Take a pic of the label and we'll be able to tell you
Sent from my ANE-LX1 using Tapatalk
Threads: 75
Thanks Given: 223
164
Paint code is KNB and the C means metallic Gwyn.
Threads: 69
Thanks Given: 7
4
Cheers Scott ,would they still sell this at halfords ?? or best go to paint shop and have it made up there ??
Threads: 75
Thanks Given: 223
164
Well I think they do, but heard Halfords paint is a slightly darker shade than the actual car. For a touch up pen it may be ok.
If you're doing a larger area then it's worth getting the car colour matched.
Threads: 69
Thanks Given: 7
4
Got my paint made up,spot on !! £20 ,had to travel a few miles to get it ,but worth it, got to practise spraying now haha ,
Threads: 75
Thanks Given: 223
164
19-05-2023, 12:33 PM
(This post was last modified: 19-05-2023, 12:40 PM by Sol.)
Brilliant. That's a fair price. Ok so a few tips:
1. Buy a cheap-ass can of spray paint from anywhere to use for practice on something unimportant (i.e. not the new paint and not on your car)
2. Warm the can before use; in a basin of hot (not boiling) water for a good few mins. Then shake it as if your getting paid £1000 to shake it. For a while.
3. Stay at least 12" away from the surface, move constantly. Build up light coats.
4. Even-coverage is king; it can always be t-cut to get a good shine.
5. Do it on a dead-still windless day and still use a wind-break of some sort. There is more crap floating in the wind that you realise.
6. Mask off everything you don't want painted, only expose the bit you need to fix. Even if it results in a square newly painted area, it is easier and neater than blasting away and trying to remove overspray later. Again t-cut can be used to feather the edges when the paint is hardened.
7. Neighbours don't like you painting their car while doing yours... Paint spray floats a long way on the breeze.
• eternaloptimist
Threads: 69
Thanks Given: 7
4
20-05-2023, 08:59 AM
(This post was last modified: 20-05-2023, 09:00 AM by my mucker.)
Ok cheers Scott ,you are always my saviour ,just laughing to myself at tip number 7!!
The following 1 user says Thank You to my mucker for this post:1 user says Thank You to my mucker for this post
• Sol
