Threads: 8
Thanks Given: 1
08-05-2023, 08:42 PM
(This post was last modified: 08-05-2023, 08:43 PM by mopedracer.)
Hi all just got a 2012 Berlingo multispace xtr with 65K miles. I was wondering what anti pollution equipment it has fitted i think it will have dpf egr but does it use adblue or other potions and what should i look out for
thanks
Threads: 75
Thanks Received: 1,308 in 1,140 posts
Thanks Given: 223
164
09-05-2023, 07:28 AM
(This post was last modified: 09-05-2023, 07:49 AM by Sol.)
No Adblue in a 2012, only DPF and the Eolys pouch system. It runs out around 100k as does the DPF lifespan. There's nothing can be done except clean the DPF or replace it, refill or replace the pouch, and then it needs coded using Citroen Diagbox and the Lexia interface. Generic OBD tools don't work, except the high end stuff (£1500 >) and of course, Diagbox which is Citroen's own software which can be had on eBay with the Interface for under £100.
You have a wee while yet I'd expect at 65k.
Threads: 8
Thanks Given: 1
been doing other thing just reading your post thanks for the reply
