TU5JP4 NFR and TU5JP4 NFU 1.6L petrol differences
Threads: 26
Thanks Received: 36 in 34 posts
Thanks Given: 143
10
Hi guys,
I know these two petrol engines are 1 in a 1000 compared to the DV6 diesels, but I cannot for the life of me work out what the practical differences are between these two TU5JP4 petrol variants that make the NFR only 90hp, and the NFU 110hp.
I'm hoping it's a simple case of a different ECU map and not down to a physically different set of cams, or cylinder head.
If anyone knows what the score is with these two, I'd appreciate it
Cheers, James
Sent from my ANE-LX1 using Tapatalk
Threads: 23
Thanks Given: 46
5
The extra HP with the 110 B9 diesel is due to a different turbo, maybe the same on petrol?
Threads: 75
Thanks Received: 1,282 in 1,134 posts
Thanks Given: 223
162
If they are both NA (non-turbo) then its very unlikely you would get 20hp from a remap on a non-turbo engine. That would suggest more aggressive cam profiles, bigger valves and perhaps VVTI timing to wring an extra 20 horses out.
But...I'm guessing as I know nowt about the Citroen petrols.
Threads: 60
Thanks Given: 228
29
10-05-2023, 02:39 PM
(This post was last modified: 10-05-2023, 02:42 PM by saskak.)
(10-05-2023, 11:53 AM)Zion Wrote: If they are both NA (non-turbo) then its very unlikely you would get 20hp from a remap on a non-turbo engine. That would suggest more aggressive cam profiles, bigger valves and perhaps VVTI timing to wring an extra 20 horses out.
AFAIK, there is no VVTI timing on the 1.6 petrol 110bhp. It is probably the valves, ECU mapping cam profiles, etc. It is an extremely simple engine, none of those fancy Japanese VVTI things , hence it drinks petrol like crazy (ask me how I know, hahaha), but can happily rev to 6-7,000rpm.
Thanks Received: 1 in 1 posts
(10-05-2023, 02:39 PM)saskak Wrote: (10-05-2023, 11:53 AM)Zion Wrote: If they are both NA (non-turbo) then its very unlikely you would get 20hp from a remap on a non-turbo engine. That would suggest more aggressive cam profiles, bigger valves and perhaps VVTI timing to wring an extra 20 horses out.
Bump
This is an older thread that wasn't really answered.. I have also a Berlingo with the the NFR engine and it's slooooooow. The extra 20hp could be really useful.
Any ideas? Anyone?
Chris
Threads: 26
Thanks Given: 143
10
(20-10-2023, 02:30 PM)Sockrancher Wrote: (10-05-2023, 02:39 PM)saskak Wrote: (10-05-2023, 11:53 AM)Zion Wrote: If they are both NA (non-turbo) then its very unlikely you would get 20hp from a remap on a non-turbo engine. That would suggest more aggressive cam profiles, bigger valves and perhaps VVTI timing to wring an extra 20 horses out.
Bump
Any ideas? Anyone?
Chris Absolutely need to get to the bottom of this conundrum. I suspect it's down to a different ECU map and probably different injectors. The valves and cams are identical part numbers for the NFR and the NFU, so can't be anything to do with those
Sent from my Pixel 6a using Tapatalk
Air filter box
Last Post: NANO_Vigo
Today 12:51 PM
ABS light, No Speedo, Loss of Power. Can anyone ...
Today 12:47 PM
Haynes K9 online manual
Today 12:40 PM
The creation of my personal solo-travellor.
Last Post: EM58
Yesterday 09:48 PM
» Replies: 22
Engine occasional hiccup, engine management flas...
Last Post: OMG
Yesterday 08:14 PM
2009 Turbo Failure.
Last Post: OMG
Yesterday 08:10 PM
Trailer Electrics - Fuses (2019 Van)
Last Post: Romahomepete
Yesterday 05:48 PM
2012 B9 Starter Motor replacement.
Last Post: Ron_man
Yesterday 04:45 PM
Locked car while driving.
Last Post: Anyinfo
Yesterday 04:18 PM
Newbie owner
Yesterday 12:35 PM
