[Warning Light] Engine fault
Hi
I recently had an issue where when I parked and locked up the car the headlights and wipers would turn themselves on. It turned out I needed a whole new fuse panel(?) as a mouse nesting in there had corroded it.
I have only been on a few shorts runs since and the engine fault warning came up on the trip computer. I ran the diagnostics to double-check. Is it possible that this light could happen because of an electrical fault even though the board has only recently been replaced? I’m worried about driving it anywhere to get it checked for obvious reasons
2013 Diesel Multispace 1560 cc Automatic
Hard to say. It needs scanned with either Diagbox or a pro scanner of some brand to see what the fault actually is. Could be completely unrelated.
Normally on the central screen, electrical faults are stated as exactly that - as in "circuit fault: alternator control fail" and not "engine fault" but you never know. Can-bus faults cause the BSI to totally freak out, but again it calls those "VAN communication fault"
"Engine fault" can be additive pump failure for example. Used for anything engine or pollution related.
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
