Question about roof bars.
Hi, I have just bought a 2017 Berlingo multispace WAV.
It doesn't have roof rails, but I may get some - maybe not immediately, but if I find a need.
I have transverse roof bars that fit to roof rails and a roofbox from my old car, and my question is, will they be long enough for the wider Berlingo.
If I had roof rails I could check, but I don't.
They are 120cm long.
If they are long enough, I'll keep them, and decide on the roof rails later, but if they are no use to me, I'd like to pass them on.
(20-05-2023, 09:16 AM)Yersinia Wrote:  Hi, I have just bought a 2017 Berlingo multispace WAV.
Just measured the roof rails on my XTR. They've about 118cm measured to the outside of each rail.
Not sure if that helps at all ...
[-] The following 1 user says Thank You to Fantom for this post:
  • Yersinia
Thanks. That gives an idea, I'll measure the max extent of the gripping parts. If I'm lucky it'll be just enough...
Post your Ghetto Fabrication / Modifications "Ph...
Last Post: Kokain
Yesterday 12:26 PM
» Replies: 38
Horn not working
Yesterday 12:04 PM
Berlingo digital cluster speedometer upgrade
Last Post: kaktusas
15-12-2025 02:48 PM
Cruise control retrofit
14-12-2025 09:37 PM
14-12-2025 01:33 PM
14-12-2025 12:49 PM
14-12-2025 12:00 PM
Anti Pollution fault warning
14-12-2025 11:39 AM
An almost Hydrolock in a DV6B
Last Post: chrisl
14-12-2025 09:36 AM
Last Post: chrisl
14-12-2025 09:27 AM
