Left mirror (only the glass, not the plastic housing) is little wobbly
Hello, as it says in the title, the left mirror is a bit wonky when i drive. What i want to know is how to remove it so i can inspect (and possibly fix) the mirror attachment points.
Thanks.
It’s pushed in and held with clips that locate when fully home. If you push it completely down grab the top edge an apply pressure outwards it should pop out. Takes a bit of pressure to make it pop. One of mine was very reluctant to come out so worked it from a different direction which did the trick.
[-] The following 1 user says Thank You to OMG for this post:
  • marko1111101
Thanks for the tip, ill try that.
Today 09:42 AM
» Replies: 54
Yesterday 03:49 PM
Last Post: rnamman
Yesterday 02:03 PM
Last Post: allanr
18-05-2025 05:57 PM
Oil consumption at 200K miles
Last Post: Buki
18-05-2025 08:29 AM
Forum activity
17-05-2025 06:32 AM
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
