Stop/water/overheat light on sporadically
2004 2.0 HDI
So the water/overheat lights randomly keeps coming on with the most annoying bleep ?
Water levels are fine and the temperature.
I’ve put up with it for long enough now and it’s really starting to drive me mad ?
I was wondering is someone might be able to point me in the direction to resolve the issue, I am assuming it’s probably the sensor?
I see a sensor on the front of the engine and also one on the battery side.
Anything else it could be.?
Thank you
Hi Gary, same happened to me afew months ago !! turned out it was the senser in the water bottle ,i took it out and the two prongs were full of shite !! the remonal is a bit fiddely its a twist and pull action,,hope this helps !!
Big Grin nice to be important,more important to be nice Wink
my ride is a  berlingo forte 1.9d 2003 model in pukey blue  Huh
Update
I changed the window washer motor and this has solved the problem ?
Thank you for the advice ??
ASDA AdBlue 10 January 2026
Yesterday 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
Blower fan
04-01-2026 09:58 AM
