Advice please from you who change your oil yourself
Is one of these, which is manual,
https://www.ebay.co.uk/itm/223385433390?...R_LroNiJYg
and
https://www.ebay.co.uk/itm/225077055426?...R-zroNiJYg
a better bet than an air or electric version?
Make life easier - go automatic. Cool
Hi John, the second one needs an air compressor. But here are my thoughts / 2p worth; if you do the change yourself, then you have to legally dispose of the waste oil, so lugging it to a recycling centre and potentially getting quizzed or having to fill out paperwork. Then there's the hassle of actually doing it - draining and refilling to the right level, changing the filter (in itself a pain) so for me, my time is worth more than paying a garage to do the service, as long as it is someone you know and trust.
Especially in your (our) later years.
Excuse my ignorance, but why would you need one of these to change engine oil?
Sent from my ANE-LX1 using Tapatalk
(25-05-2023, 12:36 PM)jemselectrical Wrote:  Excuse my ignorance, but why would you need one of these to change engine oil?
It saves laying under the vehicle James, with the suction method you can do a change from the top with no need to raise the car or take off the sump plug or undertray.
  • jemselectrical
If one does not want to be under the vehicle, I have this huge 500ml syringe that I can suck oil from the dipstick on my 1.6HDi. Sucking ~7 times is quite good and no need for pumps, electricity and so on. https://www.amazon.co.uk/gp/product/B074KQNL2Q It is cheap and unlikely to fail as compared to the rest of the electric things...
I generally use the sump bolt to drain the oil and ~150ml from the dipstick for a good measure to kind of suck all the old oil.
Yeah, there is a bit of oil spill here and there when you transfer the oil from the syringe, but with a few rags, it is not too much of a problem.
[-] The following 1 user says Thank You to saskak for this post:
  • jemselectrical
I have a guard tray under the engine components and it is a nightmare to remove in order to access the sump plug.  OK, I made an access panel for accessing the oil plug so my first reason may be wiped out.
The next problem is getting under the vehicle to access the panel I made and sump plug.  No room and a pain to jack up.  This alone is an incentive to work via the dipstick.
As suggested, I did have garage remove the oil and he used suction but this cost me a sum that made me seriously reconsider.  But he told me they suck the oil out at garages anyway!!  Go figure.
I have to confess that I have a suction extractor that runs off my compressor so I find myself  mucking about for ages setting it up which is why I wanted to get a manual one that I can use in the drive or even a 12v one.
So if you have used one how good is it?
[-] The following 1 user says Thank You to John Bilko for this post:
  • jemselectrical
Gotcha, so just for convenience. Thought I might have to spend more money
Sent from my M2103K19G using Tapatalk
Why not just get a drill pump? They sell them in Halfords dude
(25-05-2023, 09:57 PM)jemselectrical Wrote:  Why not just get a drill pump? They sell them in Halfords dude
 Got one but.......................
If you're not in a hurry to get one, keep an eye out for these 12V pumps when these are next in LIDL, I bought one about five years ago and still works fine. They cost about £15 now [think I saw them in store about a month ago] but car stuff is in stock about 4 times a year. Even lent it out a couple of times. A work colleague had a Volvo where someone had seriously damaged the sump plug and he didn't want to chance wrecking the sump to get it out, so I just lent him the pump.
https://youtu.be/KRcqsjvdPTI
Berlingo undertray
Today 06:24 PM
» Replies: 15
Today 08:32 AM
Today 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
