Threads: 3
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
To add a photo ,
Write your post , then preview your post.
Down at the bottom there is the attachment section ,
New attachment choose file
once you have chosen your picture then Add attachment
It should show in the box , as X .jpg.
Then insert into post
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 3
Thanks Brodfather much appreciated.
Threads: 75
Thanks Given: 223
164
Maybe get white tigerseal and run a smooth bead across it again. Clean with isopropanol and a rag first.
Threads: 3
I was thinking about tigerseal. Seems to be a quality product. Do you think I should remove some paint first, or just seal over everything? It's hidden as its so high and out of the way, so luckily no one will see it, so not bothered about painting it (but will do if required).
Thanks for the reply, much appreciated.
Alex
Threads: 29
Thanks Given: 67
20
It's just the paint on top of the Sikaflex, I wouldn't worry too much about it. Any PU mastic will do the job, Soudaflex is half the price of Tiger Seal and Sikaflex and it all goes off in a fortnight if you don't use the whole tube.
