Threads: 10
Thanks Given: 5
Hi All,
With the weather hotting up I was wanting to be sure i'll be nice and cool.
I've never owned a car with aircon before.. but I am not sure if my Berlingo isn't really chilling things?
Is re-gassing your aircon a normal thing to do? Or could it be a bigger issue?
2012 Citroen Berlingo M-Sp Air Xtr E-Hdi
Threads: 75
Thanks Given: 223
164
Often they do need regassed. Could also have a leak but you can't tell till the proper equipment is used on it.
Threads: 10
Thanks Given: 5
Sadly it does have a leak.
Tech doing the regas said to identify where the leak is difficult.. but most often it is the condenser so possibly cheaper/easiest to simply get one and replace that as a first step.
Does this advice track? If so, what is the part number please. Is it uniform across a lot of citroen models? thanks
Threads: 0
Thanks Received: 56 in 52 posts
Thanks Given: 38
8
I have regassed one 3 year old and now need to regas another 4 year old Berlingo.
ex: 2003 1.4i cargo / 2021 K9 XTR
Threads: 11
Thanks Received: 31 in 31 posts
Thanks Given: 3
7
Tech says there is a leak, but can't find it. That is why you took it to a specialist!!!!
He obviously doesn't have all the right gear or can't be bothered.
Geoff
Threads: 54
Thanks Received: 81 in 75 posts
Thanks Given: 147
7
I thought there was a tracing fluid they can put in the refrigerant which they can then observe leaking with a UV light. Might be worth a Google search?
Matt
2025 1.5 BlueHDi 130 MAX EAT 8 Kiama Blue
previous
2020 1.5 BlueHDi 130 Flair EAT8 White
2016 1.6 HDi 100 XTR Grey Met
2010 1.6 HDi 105 XTR Gold Met
Threads: 10
Thanks Given: 5
(03-06-2023, 09:51 PM)Matt Haigh Wrote: I thought there was a tracing fluid they can put in the refrigerant which they can then observe leaking with a UV light. Might be worth a Google search?
I've given my usual mechanic a call, see if they can do it or suggest a specialist.
