29-05-2023, 03:22 PM
OK, so this is my girlfriend's 2008 Berlingo Multispace (the newer version). It has a both airbag warning lights displaying (for the passenger airbag light as well?) and gives a beep and warning 'airbag/seatbelt faulty' (or something like that) at start-up. It does appear to have a passenger airbag (at least it has a bit on the dashboard that says 'airbag' on the passenger side and it has the deactivation switch).
We took it to the garage and (after £30 for the privilege) it was determined to be an 'airbag ECU fault'.
I've plugged and unplugged all the connectors under the driver's seat, and sprayed the contacts with contact cleaner. There don't appear to be any wires of any sort under the passenger seat; I'm not sure if it has pretensioners.
I bought a second-hand airbag ECU off eBay with a matching model number (9665250180, taken from an 09 Partner based on what's written on it in marker pen) and (after the turning everything off, waiting ten minutes, disconnecting the battery, waiting 30 minutes faff) replaced the original airbag ECU with the 'new' unit (spraying all the contacts with contact cleaner again...).
Turning it all back on again gave a single airbag light - which is at least different? I don't know if this is because the 'new' unit needs to be coded to the car, or if it's been taken from a crashed vehicle, or what. Since this didn't fix the problem, I repeated everything and put the original unit back in.
I don't know how relevant this is, but the car has previously had issues with the horn (airbag earthing?).
So what would you recommend next?
Buy a Lexia code reader thing and set up Diagbox etc to get some codes (est. £65 or so)? Presumably this wouldn't help you clear crash data off the airbag ECU or clone one unit to another (if this is required) etc. and will probably end up just indicating there's a wiring fault or something...
Go looking for the fault elsewhere? I have a reasonable multimeter but no wiring diagrams/car electrical experience. I have previously replaced the indicator stalks on my Yaris so have removed the airbag on that before if that's a good place to look.
Give up and send it to the garage for probably high costs?
The aim is to sell the car soonish and I think that will be very difficult with an airbag fault.
Thanks in advance - I did have a search through the forum but knowing how these things work someone will have posted the exact same question yesterday or something
