Strange Dials Problem
Video
https://youtube.com/shorts/PPeAhZE97Rg?feature=share
Anybody have any idea why my cluster's doing this?
I can push them so they 'spring' into a set position when there's power to the dials, but when I turn the car off and leave it until the mileage goes out (and I guess power to the dials turns off), if I open the door or turn the key and they get power again, they do that little skitty thing and drop to the bottom.
Many thanks!
Dan
(2005 Berlingo)
Hi Dan,
First of all, you're missing the gauge stops. At least on my van, when the door is opened and the BSI wakes, up, the gauges slam into the stops as a "zeroing" procedure (The needles tap four or five times against the stop and then the gauges register correctly). I'll see if I can get you a video when I'm back from holidays next week.
Nick.
[-] The following 1 user says Thank You to Ncomc for this post:
  • Dan33-uk
(08-08-2023, 07:38 PM)Ncomc Wrote:  Hi Dan,
Nick.
Hey Nick,
I ended up buying some replacement dials in the end which solved the issue so no idea why they played up in the first place. They did work fine when I first bought the van so can only assume that the actual cluster developed a fault. Now to figure out why the new cluster has the airbag light on unless they store a fault and the dials purchased are from a crashed van . Appreciate the reply though!
Dan
[-] The following 1 user says Thank You to Dan33-uk for this post:
  • Ncomc
Pug 206 ones work fine too if anyone else is needing replacements.
227,00 miles,  (Resurrected at 186,000)
triangle light
Last Post: Buki
Today 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
Last Post: wbchevron
15-07-2026 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
