[Engine] radiator fan issue
Hi all,
I just became member of this forum. My brother recently bought a renault Citroen berlingo 1.6 multispace, and we have a kind of an arrangement that I look after his car(s), and in return he takes care of the carpentry works in my house. (which is not a hobby of mine).
The previous owner of this car apperantly had issues with the cooling fan and made a "special" repair. He'd removed fuse no 16, and used the 12V supply to feed the radiator fan. The switch in between was mounted below the steering wheel.  Sad
Now we would like to repair it decently and build everything back as original. But this appeared to be a bit more difficult as expected, I have no glue how it was connected originally, or where the locations are of the accompanying components. Electrical drawings of the radiator fan wiring, and location/position drawings of the components would be really helpful. Is there somebody who can help us out with that?  Huh
VIN: VF7MFNFUB65609859
Regards Tjeerd (Netherlands)
A Renault Berlingo??
Geoff
Confused
oops.. I will change the thread
Here's the schematics for the cooling system.
Also legend for wiring, plug colours and item numbers in the drawings and the engine fusebox
Attached Files Thumbnail(s)
.pdf   Engine Cooling.pdf (Size: 119.22 KB / Downloads: 6)
.pdf   Citroen Components.PDF (Size: 153.2 KB / Downloads: 6)
.pdf   wiring legende.pdf (Size: 73.44 KB / Downloads: 4)
Engine fusebox second image
M59 unlocking itself
05-11-2025 04:06 PM
04-11-2025 09:48 PM
04-11-2025 09:15 PM
horn
03-11-2025 08:41 PM
How many miles
03-11-2025 08:12 PM
03-11-2025 08:08 PM
02-11-2025 07:53 PM
Boot liner with 7 seats
31-10-2025 07:57 PM
Last Post: Buki
31-10-2025 07:26 PM
31-10-2025 03:06 AM
» Replies: 40
