IMy 2006 berlingo m59 2.0HDI served me well the past 12 years but now it’s letting me down without giving me clear information about what’s really wrong.
Problem:
few weeks ago it suddenly gone into limp mode = no power and not going above 3000rpm. It doesn’t go immediately into this mode when the car has started. After a cool down it’s going into limp mode after a few miles/km of normal performing and the engine check light going on. When I directly start it again after this happens it goes straight into this mode.
What I already changed/checked:
- tried to do a fold reading in the body shop where I work. We have a decent reader but didn’t find anything so I already tried to change the following components:
- First thing I changed was fuel filter and air intake filter because I didn’t changed them for a long time. Didn’t fix anything.
- Then I checked the pressure on the EGR system on the exhaust and the electrical solenoid next to the battery and there’s no pressure loss on the top one and the solenoid one also holds pressure and releases pressure when giving gas as it should. Nevertheless I changed the solenoid one because I had a spare one. Didn’t fix anything.
- At this point I did run out of options and went to a citroën garage for a proper reading and they found these:
P1352: has to do something with the glow plugs. Can’t imagine that’s my problem because I have zero problems starting the car?
P0102: Airflow problem, value to low (short circuit to mass or Problem MFA itself or electronic unit motor?) I changed the MAF for a new one but didn’t solve anything.
P0113: temperature sensor of the MAF, value to high (cut circuit or short circuit to ground cable or MAF sensor broken or electronic unit motor Citroën gave as a possible problem)
P0404: EGR system not working properly. (Already check this with a vacuum checker and seemed like working properly?)
Don’t know what to do next. The car has over 13.000miles/ 220.000km so don’t want to do big money changes before knowing for sure that’s the problem (injectors, cat,...). On the other hand, the 2.0 hdi’s are known for going wel over those mileages. Also did a new clutch and power steering pump last year that costed some money.
Anyone advise of what I can or should do next??
Sorry for the long post but I wanted to give you guys (and girls) al the info I gotten so far.
Thanks in advance for your answers!
Problem:
. After running the car for 2 weeks without the limp mode appearing it’s back since yesterday
. Directly after I changed the glow plugs the engine was running almost normal apart from missing a tiny bit of power that it used to have. The day after it started to go downhill power wise on power low down the powerband. In higher revs it regained some power? So I tried to change the following during past two weeks:
