Coilovers/Custom Springs/other model compatibility
From trawling through this forum and Googling the **** out of the topic I seem to very VERY few options...
A company called Noväks used to supply a custom coilover kit made for them abroad, but after contacting them that's no longer available...
A few times I've read that peugeot 307/citroen C4 front struts can be used, is this 100% confirmed, as if so that's a massive part of the puzzle that's an easy solution...
The rears appear to be the big hurdle, as the suspension layout is unique to the models, however, at the end of the day its still a damper body and a spring.. its not ground breaking, so there must be a damper on the shelf out there the correct length + rate to suit...
The rear springs would need something similar to what I had on my Clio 172...
If the above is correct, that only really means having a pair of springs custom wound???
That's not a huge issue or expense.. I've had to do that in the past for various projects of mine......
Stu...
Yesterday 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
04-09-2026 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
