  • 17 Vote(s) - 3.12 Average
change parking/side light bulb
Can this be done without removing the headlight unit or is it a million times easier taking it out? I'm gonna give it a go in the morning but it's always handy avoiding wasting my time if someone knows it's easy one way or the other
If you have small hands its a 5 min job
(25-02-2012, 05:51 AM)muply Wrote:  If you have small hands its a 5 min job
I havent but good to know it's possible haha
i got large hands and i also put my own thread on a few weeks ago as i was struggling but after doing ii. it is fairly easy, i found it easier to remove indicator bulb as well so that you can see down the inside of the light also to take the main big circular cover off and find the wires to the side light and just tug on them slightly then the bulb will come out.
I was just going to post a thread asking this question, but am pleased I searched first... NIce to know i'm not the only one that is puzzled by the side light bulb access.....tricky one!
Slender feminine hands required . . . get the Mrs to do it while you have a cuppa :thumbsup:
[-] The following 4 users say Thank You to nil by mouth for this post:
  • j90xxx, Merlecollins, ron, steveymccombe
Do the O/S one first, it's easier!
Gives you some idea where things are, as you will be working blind on the N/S one.
Remove (as said previously) the indicator bulb AND the wiring plug on the headlight bulb. If it's a 1.6HDi (think the 2.0 is different) remove the lid off the relay/fuse box, too. Believe me, any little gains in access will help.
On the plus side, once you have done it a couple of times, you wonder what all the fuss is about...Confusedillyme:
Oh, and for some strange reason it is easier to take the plastic cover off the back of the headlight, than it is to put it back on! :brickwall:
Enjoy. :thumbsup:
[-] The following 1 user says Thank You to j90xxx for this post:
  • Merlecollins
Help
I have tried pressing what I think I should but I am scared of breaking it. Is it the small lighter coloured part on the top at the back?
What are you trying to do - remove the blinker?
Hi
Change the front side light, near sde
Yesterday 02:51 PM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
