12-06-2023, 10:34 AM
Morning All,
It appears I have lost powered steering on my 53 2.0 HDI Berlingo. Anything more than 45 degree movements of the wheel either side is a struggle to turn.
Done some research up on forums and have so far possible reasons:
Anything else I can check before diagnosing steering pump is the cause? How easy is this change?
Brad
- Pump pulley/belt appears to be turning well
- Fluid at correct level
- Possible seized universal steering joint (sprayed AC90 over this from underneath)
- Possible top strut mount bearing seized (I did have a snapped spring changed 4 weeks ago) - Jacked both sides up and wheel was easy to turn with both engine off/on - does this rule out this possible reason?
Brad
