Threads: 75
Thanks Given: 223
164
You will need to get it scanned, that warning triangle is generic and comes on for all faults
Threads: 75
Thanks Given: 223
164
(27-06-2023, 04:03 PM)howso Wrote: (15-06-2023, 10:10 AM)Katiedatie Wrote: My triangle and exclamation light keeps coming on when the air con is on or when temperature goes over 90. Has anyone had similar issues?
Berlingo multispace 2012 1.6
Check the cooling fan - should run when stationary with a/c on. Mine did this and blew fuse MF3 (very difficult to access), the fan motor was slightly tight but seems to have responded to lubrication. When the warning was on it reduced performance but this may only apply to diesels.
Thanks for this, very helpful. Katie the MF3 is a large 50A fuse located under the top tray of fuses in the engine fusebox, so that layer needs lifted up to access it.
Worth a look.
