  • 13 Vote(s) - 2.92 Average
sunflower oil
Since this is the first time in ages sunflower oil is a good bit cheaper than diesel
Can you run the 1.6 hdi 07 berlingo on a diesel sunflower oil mix
Unfortunately not.
Even the DW8 (Well the pump) doesn't like it so I doubt the HDi will either, they are much higher pressure and closer tolerances.
What about a drop of kerosene to clean it out?
And how much is a drop
DON'T - repeat DON'T - use it in any HDi.
And what about the non-turbo 1.9?
I used to regularly use veg oil in my 1.5 diesel Citroen AX, with no issues. Only problem was when it was really cold (ie below -5) and I had a 50/50 mix or greater. In fact it always kept the emissions nice and low, even over 120k miles...
I used it up to a 50/50 maximum in my XUD Xantia for a coupel of years without problem. Every so often I filled with neat Diesel and injector cleaner and gave it an Italian tune up just to shift any deposits. I imagine yours would be the same, but I would recommend some research first.
1.9 is old technology, indirect injection so more veg oil friendly than hdi engines.
  • zedhead
Is the DW8 basically an XUD with a partly electronic fuel injection system? I might try a few litres of veg oil in the next tank, every little helps. Big Grin
I think it depends on the injector pump type I remember reading on a veg oil sites that the Bosch diesel pump was okay but the other wasn't
triangle light
14-06-2026 09:30 PM
13-06-2026 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
