  • 1 Vote(s) - 2 Average
Wheels - what else fits?
I need some new wheels, mine are that rusty I cant get the beads to seal. M59 ones seem to be thin on the ground round here, I tried some off a later van and they hit the back of the wheel well on the back.
Ah! The joys of wheel offset.
Depends on the wheel diameter,
14x5.5 inch  has an offset of 24mm
15x6 inch has an offset of 18mm
I bought a set of Alcar 5,5x14 Inch ET24 4x108 for a citroen C2 & C3.
Two years ago they were £138 a set, new & delivered.
Were round & excellent.
Now? £238. Sheesh!  Huh
Fords use the same bolt spacing, but the central hole diameter is different.
230,000 miles,  (Resurrected at 186,000)
I've still got a pair of new 15mm spacers and longer bolts if you need them.
My van: 2008 Berlingo 1.6 HDi Enterprise - a bit ratty!
Thumbs Up
Cheers lads, turns out Mk1 Picasso ones are right  Smile
(23-06-2023, 12:28 PM)ItsGreen Wrote:  Cheers lads, turns out Mk1 Picasso ones are right  Smile
One possible gotcha, they might not be designed for the weight of a fully loaded van at maximum weight for 200,000 miles.
Mine is used as a big comfy car, so less of an issue.
Wouldn't think there's a lot of weight difference between a fully loaded Berlingo and a fully loaded Picasso, particularly when you see some of the people who squeeze themselves into Picasso's
Lol  Big Grin
Sad
Sob!  Sad
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
(29-06-2023, 05:08 PM)Gryffindor Wrote:  Sob!  Sad
Aw mate, not you, you're family. And being well over 6' is a different reason for having to squeeze into a Picasso.
  • Gryffindor
Well I was searching for a logical reason for the Berlingo wheel part numbers not cross referencing "lighter" cars with same diameter & offsets.
Wait!
It's French!
Logical will NOT apply.
[-] The following 1 user says Thank You to smutts for this post:
  • ItsGreen
Today 05:49 AM
Yesterday 11:36 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
