  • 17 Vote(s) - 3.24 Average
[Transmission] intermittent problem selecting gears
I seem to be getting this happen to me now and again, one day I will have no problems and the next day it will be difficult getting it to go into gear? doesnt matter which gear I try and put it into as each one will be just as hard to select. I think the problem may be somewhere under where the actual gear stick is if that makes sense? at least it sounds and feels like thats where the problem is....
Anyone had this problem before or know what the cause is? its winding me up! I thought at first it was the gear linkage but am not so sure now Sad
When I first started driving my Berli I sometimes had that problem. Finally tracked it down to my big shoes. The clutch pedal wasn't getting fully depressed and gear changing hung sometimes. No gear grinding or anything like that but it just wouldn't go in. Since then no problems. Break pedal and throttle do sometimes get depressed at the same time. Foot well designed for small folks.
[-] The following 1 user says Thank You to 3rensho for this post:
  • denlingo
cheers mate, not sure wether thats the problem I have but everything is worth looking in to!
I hve just posted a thread about a stiff change. My symptoms were very similar to yours, it was the bolt/pivot at the end of the gear lever
Last Post: BigVtwin996
Yesterday 08:25 PM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
