  • 6 Vote(s) - 2.17 Average
clunking when in third gear
hi hope someone can solve this i have 03 hdi berli every time when moving and selecting third gear i get a clunking noise sometimes is ok but mostly it happens thought it was my gear linkage rods so i changed the two small ones they were badly worn down the long one was still fairly new so that was ok but still get the clunking has anyone any ideas be much oblidged.
ah well 51 views and nobody no ideas thats the way it goes
(27-02-2012, 07:44 PM)boycie21 Wrote:  ah well 51 views and nobody no ideas thats the way it goes
Worn engine Mountings?
(27-02-2012, 07:49 PM)brodfather11 Wrote:  [quote='boycie21' pid='17611' dateline='1330371896']
Worn engine Mountings? does it happen when you let the clutch out, when you are moving ?. is it when you change down gear or up? Does it tend to wander over the road when it makes the clunking?
(I'm thinking maybe worn suspension joints).
I've just reread your original post, should have done earlier, It could be the lower suspension arm rear bushes , there is a post somewhere about them , think I read it
I would look at your engine mountings first . Put the h/brake on, put into gear, let the clutch out gently with some revs and then press the clutch . The idea is to test the engine mountings, to make the engine rock and roll, if they are worn you will hear and feel the engine moving
thanks for reply it happens when moving and only in third i fear the worst its a third gear cog or something in gear box
Berlingo undertray
Today 06:24 PM
» Replies: 15
Today 08:32 AM
Today 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
