  • 16 Vote(s) - 2.25 Average
Which engines this ?
Its not shown in the Haynes manual. The car was first reg'd August '98.
I think its the WJZ 1905cc DW series diesel.
How much difference does it make for buying spares like fan belts etc ?
Thanks in advance.
'98 D 800 van Big Grin
That looks like the 1.9D to me. Never owned one myself, but i would have assumed it was fairly simple to find parts for.
Thanks Andre - but it seems according to Haynes, that there are about 3 types of 1905 diesel. I see the XUD and DW types are mentioned but not all are shown.
The XUD is the older model, used for years. The DW is newer and can be had in 1.9 or 2.0 litre form.
Sub-types of the 1.9 DW seem to be "WJZ" - mech fuel inj, and "WJY" with EFI.
Add to that the fact that several gearboxes have been used over time (I seem to have the post '98 MA5 type from the linkage arrangement).
So I'd like a positive ID if poss.
M49 with DW8 engine. Small price catalogue:
1. Timing belts + 2 two tension rollers : 119,25 €
2. CAMSHAFT SEAL: 7,80 €
3. Radiator fan (without AC): 107,76 €
4. Water pump: 54,24 €
5. Clutch kit: 116,61 €
6. Clutch cable: 39,68 €
7. Engine(repere): 5 529,48 €
8. Gearbox(repere): 3 173,33 €
9. Left CV(without ABS): 130,90 €
10. Right CV (without ABS): 280,91 €
11. Engine gaskets kit: 48,47 €
12. Accelerator cable: 25,82 €
13. Air filter: 10,78 €
14. High pressure fuel pump by Lucas(repere): 1 677,13 €
15. Fuel filter cartrige: 11,57 €
16. AC and alternator belt(w/o AC): 22,48 €
Enough? Smile
Thx PK thats plenty for now !
I see that the DW8 is 1868cc - not 1905.
I've now found by trail and error, that the aux drive belt should be a 1110 (power steer but not air con), not the 1396 as listed at my suppliers.
(06-02-2011, 02:03 PM)colinh Wrote:  Thx PK thats plenty for now !
thats the xud engine, i had one in my last blingo, the dw engine has the plastic rocker cover, personally i preferred the older engine. Big Grin
Why is that m&v?
(16-04-2011, 06:19 AM)Andre Wrote:  Why is that m&v?
i found it to be stronger. Smile
wrr33
Where is that code shown?
Yesterday 12:02 PM
Berlingo 2026
Yesterday 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
