  • 10 Vote(s) - 3.2 Average
How do I remove the trim in back of 58 plate van
Hi,
I'm going to install a reversing sensor kit to the van that my wife has just bought for her flower business. Having looked at a new van that has factory fitted sensors I'm looking to route the cables in a similar way but to access where they route up through the floor I need to remove the rear left hand side internal black plastic trim, can anyone advise how this is fitted in place? I don't want to risk snapping any plastic fittings off the panel.
A mechanic would give it an expertly positioned wack and off it`d come. The rest of us have to use a screwdriver. If you`re careful, you`ll be fine. I did this on mine wi out wrecking it . . .
Check out " permanent live in boot area of mkIII berlingo " thread for advice on removing panels.
Im gonna have to remove mine I got a number plate light out.
I DO MISS MY BERLINGO Heart
Philip, I thought you just had to remove the lens by inserting small screwdriver into bulb lens slot from exterior of tailgateto access the actual bulb
1.6hdi starting problem
Today 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
