  • 30 Vote(s) - 2.6 Average
[Tires & Wheels]  Correct Tyre Pressures
Hi does anyone know the correct tyre pressures for a Citroen Berlingo 2005 2.0 HDI Van with 175/65/14 tyres? im currently running 48 psi front and back but it seems to hard a ride,and i all can find is conflicting info many thanks in advance
Call your local dealer?
I DO MISS MY BERLINGO Heart
What does it say inside drivers door ?
48 psi is alot...!
No wonder it's a hard ride!
There are normally two levels, normal and fully loaded. Normal is usually 30 to 35 psi or thereabouts.
48psi!!! No wonder it's bouncy!
34 all round for light load and a couple of pounds extra in the rear when loaded. My door/ A pillar sticker says 2.3 bar all round for light loads....I have a 1.6 tdi on 15" rims but the difference will be only a little.
Try here: http://www.tyre-pressures.com/
  • Grem
(28-02-2012, 10:32 PM)OlJeffers Wrote:  48psi!!! No wonder it's bouncy!
Mine says 2.7 Bar Front =39 psi
3.3.Bar Rear = 48 psi
Same pressures for loaded as unloaded doesnt make sense?
I suppose if your van is an 800 on 14" tyres the difference is because of the sidewalls being taller than on a 15" tyre.
When I had 14's on my 2.0 hdi 800 van I ran it at 36 psi.
On 15's it's at 36 psi.
48? Yoikes!
(29-02-2012, 06:57 PM)OlJeffers Wrote:  I suppose if your van is an 800 on 14" tyres the difference is because of the sidewalls being taller than on a 15" tyre.
Yes it is an 800 on 14" tyres
I run with 35psi front and 33psi rear when empty, 35 if loaded.
The sticker states same figures loaded and empty, which seems strange.Confusedcratch:
[Image: 246ti5s.jpg]
Sorry, Andre for my BIG pictures...
Yet another ABS fault
Last Post: leftfootleashed
Today 09:09 AM
Today 06:29 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
20-04-2026 02:30 PM
