  • 22 Vote(s) - 3.45 Average
idle speed
my dw8 engine always idles just over a thousand is this correct and if not how do you adjust it
http://www.berlingoforum.co.uk/showthread.php?tid=2432
[-] The following 1 user says Thank You to steve valentine for this post:
  • j90xxx
I would suggest that your idle speed thermostat is kaput. Mine failed and keeps the revs high. As soon as the engine has warmed up the revs should drop back noticeably. Part is £30 ish. I have another post on here about it, i'll find it.
http://www.berlingoforum.co.uk/showthrea...4#pid13124
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.Confusedalut:
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
