24-06-2023, 10:11 AM
Could somebody please tell me where the cig lighter socket fuse is on a 2009 b9 berlingo
Bit of background
The car wouldn’t start the other day so I called the breakdown services
There were lights on the dash but no solenoid click from the starter when turning the key
The breakdown chap tried a jump pack to no avail
He then removed the battery and tray to try and access the starter but couldn’t.
He refitted the tray and battery and we bump started the car by pushing.
The car went into the garage and I collected it yesterday
The garage said
Inspection found no feed to starter solenoid
Traced to damaged wire in the bcm
Repaired and soldered
Replaced fuse and tested ok
The car starts fine now but I have lost voltage to the cig lighter socket
The front Center interior light works when you open the doors but the two switchable interior lights either side don’t work .
Bit of background
