(06-03-2012, 02:00 PM)malcolmph Wrote: Hi
I have a 2005 Berlingo van 2.0 HDI. Can anyone advise whether this is OBD II Compliant???
i bought a Garmin Ecoroute HD and have plugged it into the OBD port under tha steering wheel. The Sat/Nav and smartphone both detect it and yet fail to connect to obd
at the same time it will not allow me to setup the device if the vehicle is moving so it must be getting some sort of reading from the engine..
any help
Hi
I have a 53 Plate 2.0 Hdi & Garmin Ecoroute works fine so you should have no problems.
It would be worthwhile checking your fuses when battery is disconnected using BSI reset procedure as follows :-
Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
Ensure all doors are closed and remove key from the ignition.
Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds.
CHECK YOUR FUSES NOW & replace any failed fuses then shut the drivers side door again.
Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.).
Switch on the side lights through the driver's window.
Switch on the ignition and check system's functionality.
Hold lock button on key down for 10 seconds.
Remove key open & close door test central locking system.
Start the engine and complete the system's check.
Failure to follow this procedure could result in incorrect operation of many BSI related items
On my MK2 (M59) HDI the diagnostic socket is Fused 10 Amp(red fuse) Fuse is located in the BSI unit, fuse number F6.
BSI unit is just below the diagnostic socket.
I had a similar problem with mine because of blown fuse it would not connect to Ecoroute HD or Lexia diagnostics because of blown fuse[/color][/u][/color][[/u]
