Electric handbrake
When I put it in reverse the handbrake doesn’t want to disengage it does eventually but its stubborn,
It is automatic isn’t it or should I be pressing the button by the gear stick? Moving forward is fine
Anyone else notice this? Another problems is when I go into second gear there is a loud clunk from the gear stick which is very annoying anyone have these problem? 2023 enterprise. Thanks
The electronic handbrake should disengage automatically. I would get that sorted ASAP, since it happened on our C4 Grand Picasso, and we were completely stuck. Even the AA couldn’t sort it at roadside, and had to totally disconnect the handbrake.
There has been a recall for a software update a week or two ago, to remedy a communication problem which can cause loss of drive. I don’t suppose that this is the cause of your problem, but it is a possibility.
They can no doubt look at the second gear clunk at the same time.
2022 E Berlingo Feel M, in Cumulus Grey, with reversing camera
(27-06-2023, 01:06 PM)ratboy72 Wrote:  When I put it in reverse the handbrake doesn’t want to disengage it does eventually but its stubborn,
Are you on a slight incline when reversing? As stated, it should release automatically but it may be affected by the hill start part of it.
With regards to the second gear clunk, something doesn't sound right there. My EAT8 gearbgox is smooth as silk
Thanks for reply’s, I will have to check on the incline bit as you may be right as it doesn’t do it all the time thinking about it , the clunking is coming from the gear stick itself underneath the cover? I’m not really that bothered as it’s a company van but I’m quite anal on things being perfect. Thanks anyway.
Are your doors closed? I have had it refusing to release if a door is not fully closed.
2020  1.5 Blue HDi 130 Berlingo XTR
2009  1.5 Diesel Peugeot Partner
2007  1.5 Diesel Berlingo Desire
2003  Petrol Berlingo
All sorted it was the hill assist making it lock for longer. Cheers
BSI
Last Post: Zion
Yesterday 06:47 PM
» Replies: 26
Dropped a valve ?
Last Post: james1089
Yesterday 05:34 PM
» Replies: 24
HELPPPPPPP, citroen extended warranty team rejec...
Yesterday 05:20 PM
Add blue / engine fault light
Yesterday 05:13 PM
Newbie
Last Post: Rosemerry
Yesterday 02:48 PM
Electric probs - where to start
Last Post: Zion
Yesterday 10:58 AM
Replacing wings
Yesterday 10:01 AM
Sliding door rattle
Last Post: melpa
Yesterday 12:57 AM
New to Berlingos - Impressed so far!
Last Post: RichCowell
29-09-2023 11:03 AM
Appropriate Jumper Battery
Last Post: Abaddon
29-09-2023 09:38 AM
