Threads: 2
Just had water pump and timing belt done today, it whines ! .. I guess this is too tight. However I'm going to scotland in it tomorrow for a week and can't get it back to the garage for adjustment.
Wil it be ok ? Can I adjust it ??
Threads: 32
Thanks Given: 18
Did they fit new tensioners as well?
Threads: 2
09-03-2012, 06:56 PM
(This post was last modified: 09-03-2012, 07:02 PM by Baz2963.)
Mmmm don't know about that ...
I got charged £85 for a timing belt kit, do they come in that ?
Threads: 13
Thanks Received: 57 in 48 posts
Thanks Given: 7
A kit should come with belt and pulley(s). I would have asked to have the old bits back. Does sound as though it may be to tight. Citroen use a special electronic 'tool' to measure the tension that clamps over the belt. Its known as a 'seems' device and measures 'seems' units which are like no other! Having said that I've done both petrol and diesel variants of bingos and used the thumb and forefinger 90 degree twist method. Works for me!
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.
alut:
Threads: 2
Does it need slacking off or will it be ok ?
Threads: 2
Took it back to garage and they were glad I did, it was actually too loose which was making it sing !!
Threads: 32
Thanks Given: 18
I'd be considering taking it somewhere else in future!
