Threads: 0
10-04-2012, 02:57 PM
(This post was last modified: 10-04-2012, 03:01 PM by thewarbyte.)
Had same problem. Horn works with no key in ignition. Doesn't work with key in. Looked on t'internet and came to the conclusion that it was an earth fault. The circuit doesn't go via any fancy electronics unit. It goes through 2 fuses to the horn switch ,horn and to earth - that's it. Tried to get front bumper off to get access to the horn to check the earth wire but after struggling for ages trying to unclip the final 2 clips at either wing I gave up. I eventually found a solution that worked for me from a post on this forum. Run an earth wire from the steering shaft to a good body earth. I have put a clip around the shaft and fastened a wire to the clip. I guess the return must earth back at the horn switch somewhere and relies in the steering mechanism to be earthed somehow via the ignition switch???
