Threads: 39
Thanks Given: 1
4
Please can somone tell me what size Torx bit is needed to remove the caliper mounting bracket from the front hub.
Trying to get all the tools sorted in preparation for fitting new disks and pads
Peter
Threads: 75
Thanks Given: 223
164
I've a feeling it was a T30 Peter, but @
jj9, @
Gadgetman or @
saskak will know.
• jj9
Threads: 8
Thanks Given: 305
36
I've just checked them on my car as I couldn't remember and they're T55.
• Sol
Threads: 75
Thanks Given: 223
164
I've got a Teng set the same as this. I just pick one that fits too. But some folk just buy bits as required.
Threads: 48
Thanks Given: 4
20
Buying them separately is cheaper only as long as you never need more than a few of them.
Buying sets have saved me from a lot of desperate 'must reach HW store before closing' rushes. And those rushes are extra difficult if the car is in pieces, and the store is 20Km or more away...
I also have an 'after the fact' rule; that if I bodge through a job, but there exists a tool that would have worked better, I buy that tool the next time I'm at the HW store. If it's part of a set, I buy the set.
This rule has saved me from a few mad dashes, too.
The following 1 user says Thank You to Gadgetman for this post:1 user says Thank You to Gadgetman for this post
• Sol
Threads: 39
Thanks Given: 1
4
Thanks all, I do have a set of torx bits and some loose ones. Now that I know hat size to look for among my loose ones.
I like to have everything ready before I start a job
Peter
Threads: 29
Thanks Given: 67
20
Be sure to knock the bit into the head well with a hammer before you try to undo it as they are threadlocked and the heads are shallow.
Threads: 39
Thanks Given: 1
4
I have done the job a few times before, imprtant to clear the socket out before starting to remove
Peter
Threads: 61
Thanks Given: 234
29
I am nearly certain they are T55. I use a breaker bar from Halfords and I think I bought the T set from Halfrods as well. Have used it quite a few times now and none of these have broken.
