Threads: 4
Thanks Given: 3
Does anyone have any tips for removing the offside engine mount. I’ve just broken a new strap wrench on it. I’ve tried a chain type oil filter wrench but there’s no room to swing it.
Threads: 48
Thanks Received: 272 in 229 posts
Thanks Given: 4
20
Offside engine mount?
Is that righthand or lefthand side?
(As seen from the drivers' seat, facing forward)
And which engine?
Threads: 11
Thanks Received: 32 in 32 posts
Thanks Given: 3
7
OH Boy, that guy on Youtube could waffle for his country!!!!!!!!!!!
Geoff
Threads: 48
Thanks Given: 4
20
I bet Citroën has a special tool for that part. Just a socket that fits over the durn thing and has 3 tabs to latch onto the gaps.
I'd try a chisel and hammer, really, if I could get to it. Or make a tool for the job.
Or give the base of the durn thing a squirt of two of WD-40
As for the glove trick, you need a Nitrile glove like he has, but try to only use a single layer. Nitrile on top of nitrile will just slide.
Threads: 11
Thanks Given: 3
7
But he had the glove in the wind-up section, which cannot slip. The bit that slips is round the circumference of the bush. It looks to be an M8 fixing, so a couple of taps with a hammer and punch and it would have been off in seconds. It is not as if it matters if the old bush casing gets damaged.
Geoff
Threads: 26
Thanks Received: 32 in 29 posts
Thanks Given: 9
10
Fleabay for the 35mm impact socket that you will eventually be needing for the driveshaft nuts.
It also fits that pointlessly rubbery engine mount bolt.
227,00 miles, (Resurrected at 186,000)
