  • 5 Vote(s) - 2.6 Average
done a seat rebuild
well i got fed up with the seat killing my butt.ive read lots of people with the same problem and no one having any luck with finding something else to fit . so today i removed my seat and after removing the cover (took a while ) i covered all the foam base with a 1 1/2 inch layer of extra foam. i was going to use 1 in memory foam but ended up useing the thicker. after cutting the new foam to shape i used spray glue on both surfaces this stuck them together nicley. the hard bit was getting the cover back on with the extra thickness,there is 9 plastic clips on the base cover that need to go through the foam and clips on to metal bars that run under the foam base these took me ages to get back on . then it was just a matter of streching the cover back over the frame and replacing the metal clips under front and rear of seat base,what a wrestle. ive replaced the seat now and it looks to be good with much more padding to it. i havent had chance to try it yet but i hope it has done the job. all in all it took me around 4 1/2 hours to do . so to morrow ill find out if it was worth the trouble.
[-] The following 1 user says Thank You to landcrab for this post:
  • td5
Ive Subaru wrx bucket seats fitted in mine
well thats sorted the seat much better now.also when the seat was out i found the wire that was broke off causing the air bag light to be on.
I took the cover off my van seat, but the seat foam had started disintegrating, on the drivers side. Had to be careful not to make it worse putting the clips back on. Feels like there's a hole in the seat now
Just got a car, feels a lot more like a bench
https://www.berlingo.org/showthread.php?t=28671
Berlingo M49 multispace 2001 1.6 16v TU5JP4
I got some peugeot 306 seats to put in, but couldn't see how they would fit, and now I have bought the car I'm not sure it's worth the effort
Today 05:26 PM
Air filter box removal
Last Post: Harrythephot
Yesterday 11:03 PM
Berlingo undertray
Yesterday 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
