M49 Diesel Fuel Tank - syphoning
Hi everyone. I have an issue with my 2000 Multispace 1.9D fuel sender. My fuel gauge is showing empty and it is NOT the gauge itself as it has been checked.
There is no inspection access to the sender unit on the tank, which is a real pain.
I am therefore needing to drop the tank, which is three quarters full. I am assuming that I will have to drain the tank to do this and there is no work around.
1. Is it possible to syphon fuel out on this model through the filler ?
2. How easy is it to remove the tank and disconnect the fuel lines?
I hope that someone might have done this before.
Thanks for any help/ advice.
Tim
Never tried to syphon out of tank but would think its possibly/easier through the fuel lines at the filter. Disconnect the fuel line to the filter add your own bit of pipe. There should be a handpump on the fuel line from tank to help getting the fuel flowing.
If you have a car lift then its quite easy , mucky dirty job otherwise.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
  • timpascoe
I have learned that it is not difficult to syphon diesel out through the filler. The neck into the actual tank has a butterfly on it but it is straightforward to insert a hose and this flips open to allow syphoning.
triangle light
14-06-2026 09:30 PM
13-06-2026 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
