There are 3 things i want everyone to be aware of.
New Thanks System
We previously had a reputation system whereby you could 'rep' someone if they helped you, or made you open your eyes to something, or whatever. However, i didn't think this quite fitted with what we were about, so we now have a 'Thanks System'.
You can Thank someone by clicking the button on the threads, if they helped you out, solved your issue or anything else you would thank someone for. Even if you had no input to the thread, but found the info useful, you can Thank the person also. Please use it, as it will help to add some dimensions to the members we have, useful feedback loop to have!
New Support System
When you post in the Technical Help Area, your thread will have Not Solved next to it. This is in place to make this forum more accessible, and more useful as it's prime use, as an online resource. Once your issue is solved, we will mark it as such. So try and make it clear that you ahve had your issue solved by at least responding to the person trying to help you!
Once again, this is a feedback loop and should prove really useful. Saving you and others from trawling through pages of threads.
Thread Rating
We have had this from Day 1, but it hasnt been used much. I'm not asking you to go all out rating every thread you read, but it would be nice if you rated threads honestly, and annonymously. Once again, im just trying to make this place effective, where useful threads gradually sift themselves to the top!
I'm going to try and cut out all the teething problems and integrate the above smoothly into the forum, but at least the infrastructure is there.
New Thanks System
New Support System
Thread Rating
