Threads: 5
Thanks Given: 3
Hi all, quick question concerning my 2014 B9 1,6hdi with 187k kilometers on it. Recently I've noticed at Idle with the clutch disengaged (neutral, foot off clutch pedal) I have a rumbling sound which disappears once the pedal is depressed, am I correct in assuming that this is a bad bearing in the gearbox itself and not the clutch release bearing? The clutch was replaced at about 125k kilometers 4 years back including pressure plate and release bearing.
I was hoping to hang onto the Berlingo for another 18months or so when it will no longer be permitted in our ULEZ zone and look to replace it then.
How likely will it hold out another 20k or 18 months ? Or is it still worth fixing?
thanks
Threads: 18
Thanks Received: 24 in 24 posts
Thanks Given: 37
Sounds like the thrust bearing to me. Bearings in the box usually whine all the time and the noise escalates with speed . Would thought it would last a while if it’s only just started being noticeable.
The following 1 user says Thank You to OMG for this post:1 user says Thank You to OMG for this post
• Yamato 41
Threads: 67
Thanks Given: 238
50
08-07-2023, 08:30 AM
(This post was last modified: 08-07-2023, 08:31 AM by geoff.)
I'd have thought the release bearing ...... lifespan ??
Making it last could involve a change in driving style, eg :
Not holding the clutch down / in gear when stationary in traffic or indeed at any time ( do you do that ? )
Flicking the box out of gear before you stop, ie coast the last few yards
Change from 1st to 3rd when possible, similarly 3rd to 5th etc
Move off in 2nd on a downhill
Going down the box - let the box stay in a higher gear and use the brakes more rather than going through all the gears
Esentially any method of not / never pressing the clutch pedal down and when you do just minimise the time the pedal is held down to an absolute minimum
Serieal Berlingo owner
• Yamato 41
Threads: 44
Thanks Given: 97
28
09-07-2023, 01:51 PM
(This post was last modified: 09-07-2023, 01:58 PM by Gryffindor.)
In the last few months before the ULEZ ban comes in, a lot of people will be selling off non-compliant vehicles, so the sales market will be saturated and prices will crumble. Sell yours before then.
I suggest you put it right soon, ready for sale in say 3 or 9 months (I would have said 6 but winter is not a good time to sell cars), and then use that time to save up for and source its replacement.
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
Threads: 44
Thanks Given: 97
28
09-07-2023, 01:54 PM
(This post was last modified: 09-07-2023, 01:55 PM by Gryffindor.)
(08-07-2023, 08:30 AM)geoff Wrote: I'd have thought the release bearing ...... lifespan ??
There speaks an experienced driver.
53 1.4i MS MPV RIP
08 C4GP 1.9 VTR+
