2 problems with 1.6 bluehdi
Hello
I have two problemes regarding berlingo 1.6 bluehdi 2016.
1st problem is that with a squealing noise when ac is on at low rpm's when ac is off the noise is gone, I have new ac compressor.
2nd problem is that sometimes only hot air is blowing on windshield and I cant change direction or temperature.
Thanks for help
It could be the drive belt causing the squealing , try pouring a little water on the belt when it is making the noise .
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
