Wiper linkage
Hi all help wanted !! just driving down road and one wiper stayed the left and other stayed to the right while wiper motor still running !! so i am thinking its wiper linkage ?? so how do i get at the linkage, it looks like from above ?? any help would be much appreciated, TIA Gwyn
Big Grin nice to be important,more important to be nice Wink
my ride is a  berlingo forte 1.9d 2003 model in pukey blue  Huh
ok, went ahead and tackled it without knowing what i was doing !! any way after removing everything except wiper motor ,the two rods which are connected together on the central pivoting thingy that operates n/s wiper ,the plastic?? inserts in the holes of the rods are drastically worn away !!!,so does anyone know if there is anywhere i can purchase replacement inserts ??TIA Gwyn
Sorry Gwyn I wish I knew, but I'm sure you will get someone along who knows about spare parts for the M59.
No probs Scott,found a supplier on line who sells steel clips that you slide on over the holes and the ball joint and then you slide some wire through two holes opposite each other on the clip to stop the rods coming off !! so we'll see if it works friday when they arrive !! I'll let you know !!
Sounds good mate, post up details if you can. This sounds like a great find.
I have done the wiper linkage on my lingo now,all working good now,and it sounds a little quieter i fancy !! If anyone has the same problems please go to :- askthemechanic.co.uk I'm sure he'll have the parts for your model, and other models as well ,I'm not on commission honest haha,
06-10-2026 04:12 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
