Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
Does the Mk.2 Multispace or Peugeot equivalent come in white.
I am looking to change my van side door to one with a window.
Don't want to go down the road of buying a secondhand coloured door and having it resprayed.
Don't remember seeing a Citroen in white. Could be wrong...
Threads: 63
Thanks Given: 410
Martin, the window arrangement on the side door and rear side windows is a bit piss-poor for security and could easily be forced open, I fear.... There used to be local firms (Midland Plant Glazing for one) who could cut an aperture out of a panel and fit a solid glass sheet with rubber surround....
Threads: 101
Thanks Given: 384
Thanks Andy.
You have answered my next question.
Must have new batteries in your crystal ball....
Threads: 63
Thanks Given: 410
Had a look at the rear side door on mine today. The rectangular glass window sort of sits on the ouside of the housing and on the rubber insertion. Although the glass is rectangular, the aperture behind is partly made up with a curved rib so potentially a no-no for a solid glass window unless considerably smaller than the surrounding structure of the door, if that makes sense.
Threads: 101
Thanks Given: 384
Thanks for checking, Andy.
The upper part of my door (windowless) appears to be plastic.
Still can't find one in white.
Unless anyone knows different...
