Wipers B9
Hi can anyone help my wipers on my 59plate xtr. has 3 speed settings on front wipers, intermittent, constant, fast constant. When I select fast constant there is no increase speed from the constant setting. Thanks in advance
Can only think it's a problem with the stalk communication unit, called the Comm2000 which sends your stalk requests to the BSI (Body Systems Interface) which is the computer living behind the glovebox.
The Comm2k units can get issues, switches can go bad, get broken or corroded etc. Good news is they are interchangeable without coding unlike most other electronic parts on the Berlingo.
Only thing is that it has to be identical to the one you have already. Probably worth removing cowling and give it a good dose of electrical switch cleaner (don't use anything else) and work the stalk up and down a few times, see if it fixes things.
Unlikely to be the motor or it would stop on the high speed settings rather than stay the same.
Yesterday 05:20 PM
How to change your username
Yesterday 09:35 AM
K9 5 speed dual mass or not?
Last Post: kingy1912
05-12-2024 11:17 AM
Egr problems
05-12-2024 11:13 AM
Oil around intercooler + low oil warning
Last Post: rorova5
05-12-2024 11:10 AM
ABS light, No Speedo, Loss of Power. Can anyone ...
Last Post: ThomasTheTMC
04-12-2024 11:25 PM
» Replies: 15
Part number help please ?
Last Post: Gollycrush
04-12-2024 05:23 PM
oil seals
04-12-2024 12:52 PM
Brake light switch
04-12-2024 11:16 AM
Clutch Bleeding
03-12-2024 08:37 AM
