  • 15 Vote(s) - 3.2 Average
Clutch Pedal Really High! Is It Adjustable?
Hi Folks
I just got a 1.4 Berlingo Multispace MK I and am enjoying the whole experience. But the clutch pedal is really high compared to the brake and accelerator pedals. Can I Adjust it and if so How?
Thanks in advance for your help
Brian
Hi Brian,
Quote from manual
Having slackened pedal pivot bolt
1.Slacken the nut & bolt securing the pedal stop-plate to the pedal bracket
2 Using a lever raise the stop plate fully so that there is a considerable amount of free play at the pedal
3 Lower the stop-plate until there is between 1.0 & 3.0 mm free play at the pedal. Hold the stop-plate in position and tighten retaining nut.
Hope this helps. If you are going to keep the car I strongly advise getting the Haynes manual (No 4281) as it will save you £s on basic stuff
Regards,
Griff
Landmark
Ex 1.4 Berlingo Multispace
Cheers Griff
Just what I needed Smile I have ordered a Haynes Manual and wait its arrival
Thanks Again
Brian
Yesterday 03:36 PM
Last Post: JPCoetzee
Yesterday 10:34 AM
13-03-2026 09:14 PM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
