  • 26 Vote(s) - 3.12 Average
KNOCKING/VIBRATION NOISE COMING FROM NSF
Hi folks i have recently replaced near side front spring after it had snapped then there was a knocking noise, so i changed the drop link hoping this would cure it as there was a tiny bit of play in it but it is still doing it.
it is a strange one as it doesnt do it all the time and tends to do it mainly over small bumps which are frequent then sometimes it will send a vibration through the car as if it is rattling against a body panel or the bulk head. i have had a look and cant physically see anything and i thought it might have been the wheel arch liner as there is a clip missing but i have replaced it now and the fault still persists, so if any one could shed some light for me it would be greatly appreciated as i hate annoying noises
i feel like hitting my :brickwall:
check if the strut is seated at the bottom properly.otherwise the top of the spring hits the inner wing.you will see where it rubbs the underseal off if this is the case.
[-] The following 1 user says Thank You to lorraine for this post:
  • BerlingoHDI
Might sound a bit thick here but how do you mean seated properly.
If the spring is in the cups correct i think Lorraine means
[-] The following 1 user says Thank You to muply for this post:
  • BerlingoHDI
OK thanks for that forgot to mention as well I think it is worse when someone is sat in front passenger seat
(16-03-2012, 05:05 AM)BerlingoHDI Wrote:  Might sound a bit thick here but how do you mean seated properly.
hi.is the lug on the bottom of the strut seated between the clamp on the bottom.it stops the leg spinning when the wheel is turned.there are two more thicker ones just above it.hope this helps
  • BerlingoHDI
the roll bar is mounted on the chassis on two rubber bushes in addition to the droplinks, i woluld be looking at those if it was me.
[-] The following 1 user says Thank You to Gemmima for this post:
  • BerlingoHDI
Worth checking the track rod end and balljoint too IMO. Jack the car up and see if theres any play in the wheel Smile
Sent from my BlackBerry 9800 using Tapatalk
'04 Peugeot Partner HDi LX. Lows, Leaks and Wellers. Now matt grey and dent free Smile
[-] The following 1 user says Thank You to PeteA for this post:
  • BerlingoHDI
Thanks everyone for all your opinions, i have checked roll bars and track rod ends etc and all seem to be fine, i will check the lug on the bottom of the strut tomorrow as lorraine said, will be back to let you all know as it is starting to annoy me now.
My knock was a track rod end, wasn't picked up on mot either!
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.Confusedalut:
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
