My 2016 Belingo sliding door inside has noise when speed up or turning every time. Have any one also has this issue. And now I would like to tear down the inner panel. have anyone can release the assembly informaiton. Is the panel only has one screw in the side wall of panel.
Threads: 29
Thanks Received: 38 in 33 posts
Thanks Given: 146
11
Is it a van or a Multispace?
Sent from my Pixel 6a using Tapatalk
Threads: 75
Thanks Given: 223
164
23-07-2023, 09:48 AM
(This post was last modified: 23-07-2023, 09:49 AM by Sol.)
The interior trim panel does rattle on all B9s. You can find an area on the panel where additional screws can be fitted after drilling a pilot hole but apart from that, you can't do much about it.
I stuffed cotton waste roll (insulation stuff) into that door and put an extra screw in to hold the panel down. Mine makes no noise now.
Thank you for sharing your experience with the interior trim panel rattling issue on the B9. However, I've checked and it seems that the noise I'm hearing is caused by something loose inside the panel, because the issue is only present on the right door. Could you please provide me with more information on how to remove the panel? I couldn't find any information in the service manual. Thank you!
Threads: 75
Thanks Given: 223
164
No idea. We aren't Citroen, we are volunteers and private owners. You're the first person to ask this..
Buy a Haynes manual from Halfords, it will probably help with that job.
