  • 8 Vote(s) - 3 Average
Couple of quick (and obvious) Questions
These are probably answered somewhere but I tried searching for service reset and reset and resetting to no avail.
2004 1.9 multispace
How do I reset the service interval display on the dash? I have no manual otherwise I'd look it up.
What is BSI reset which I've seen mentioned a couple of times?
Malc
Hi to reset service indicator I think you have to hold in the trip button while ignition is off and whilst still holding it in you switch on the ignition then there will be a countdown from ten to zero once it has finished counting down you may let go of the button.
I believe that is how I did mine so hope it works for you and regards to Bsi reset I believe the bsi is some sort of ecu and you follow that procedure when disconnecting or connecting battery. And also to clear electrical faults I believe. I am sure someone will be able to explain better than I have.
(16-03-2012, 09:06 AM)crickleymal Wrote:  These are probably answered somewhere but I tried searching for service reset and reset and resetting to no avail.
2004 1.9 multispace
Malc
Try this
http://www.berlingoforum.co.uk/attachment.php?aid=27
Try the BSI Reset procedure as this may cure your faults:
Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
Ensure all doors are closed and remove key from the ignition.
Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds.
Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.).
Switch on the side lights through the driver's window.
Switch on the ignition and check system's functionality.
Hold lock button on key down for 10 seconds.
Remove key open & close door test central locking system.
Start the engine and complete the system's check.
Failure to follow this procedure could result in incorrect operation of
(16-03-2012, 12:11 PM)muply Wrote:  Try the BSI Reset procedure as this may cure your faults:
Umm... What faults?
of what?
Thanks though. Procedure noted.
Anything electical eg wiper locks lights
Today 12:02 PM
Berlingo 2026
Today 03:17 AM
Yesterday 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
