Threads: 6
Thanks Received: 1 in 1 posts
Thanks Given: 6
The stock speakers sound significantly better with just an amp upgrade.
I used a t harness so there was no cutting of any wires and due to the modest power of the amp I used, I didn't need to feed a supply from the battery.
Threads: 2
Thanks Received: 56 in 52 posts
Thanks Given: 38
8
Did you have the head unit's built in DSP set to flat?
ex: 2003 1.4i cargo
Threads: 75
Thanks Given: 223
164
27-07-2023, 06:45 AM
(This post was last modified: 27-07-2023, 06:49 AM by Sol.)
It's in the stereo menu! No need for a garage. Set DSP to Trance. Honest (if it's still called that on the K9 HU). You'll then probably find the amp wasn't even necessary.
I set my B9 DSP / equaliser to Trance and the bass was off the chart on Dub or Bob M. / Damien Marley.
Chronix....Here Comes Trouble.....what a tune.
Linton Kwesi Johnson...Street 66...
Threads: 6
Thanks Given: 6
I did that and you're right it does make a big difference to the stock setup. However, the amp makes a bigger difference. Once I upgrade the speakers, it'll be even better.
There is an option in the car diagnostics to set the dsp for the 8 speaker focal setup, the stock speakers and a flat dsp for aftermarket speakers. I thought that's what you meant.
Threads: 75
Thanks Given: 223
164
Ah ok no worries. Glad youre happy with the setup though. Not may folk have messed with the K9 yet.
